SCR-P "Lode Runner" (5x cERSlas, 2xcERPPC)
Thread in 'Stormcrow Omni Builds' started by Roegan, Nov 5, 2014.
  1. Roegan
    Roegan Junior Member
    Made this since they boosted ERPPC's speed back up a bit to acceptable levels. You shouldn't be alpha'ing in this build, it's more of a dual role build. That being said, this CAN sustain a single alpha as long as you're not above 35% heat.
    ERPPC's for sniper mode. (They're really close to your head, so where you point is where you hit.)
    5x cERSlas for brawl mode or "I'm running hot". (nearly equivalent to 5 IS Mlas, slightly less range, 1 less heat per laser)
    Module recommendation:
    -Radar Deprivation
    -cERSlas Range 5
    -Advanced Zoom (with mastery)
    Also be sure to bring along a cool shot for those moments when things get tight.
  2. Regina Redshift
    1,293
    Seems like a solid idea. A nastier version of the Nova dual cERPPC sniper.
  3. SparePartsBin
    SparePartsBin Active Member
    78
    As soon as I buy the Prime It will be outfitted as such.
