SCR-Prime "Wrongdoer" (3xcATM6, 2xcHML, 2xcERSL)
Thread in 'Stormcrow Omni Builds' started by Excalibaard, Aug 24, 2017.
  1. Excalibaard
    5,292
    How I've currently set up my ATM stormcrow. The combination of ERSL and HML sets it apart from most boats I think. I'd love to get an active probe or TC in there, but the ammo is more necessary and I like the relative symmetry of the double heat sinks.
    Best compromise I could find is to take 2xATM9 instead, and use the half ton gained for cLAP.
    3xATM6: 10.5t, 13.5heat, lower spread, clustered volley
    2xATM9: 10t, 14heat, higher spread, disperse volley
  2. Excalibaard
    5,292
    ATM9s version, LTAG or cLAP is up for preference.
  3. Asymmetric build with SCR-A quirk(s).
    If you want a Light Tag, you could trade 2x ERSL for another HML and fit it in the arm.
    How often are you using the HMLs? How often outside of 200 meters?
    I may try this and go with 6x ERSL and give up a bit of range for duration, cooldown and dps.
  4. Excalibaard
    5,292
    Ooh good call on the set of 8!
    I love heavy lasers personally, and use them up to 320m as long as heat allows. if you'd prefer to go pure ersl i don't blame you!
    Though when you look at quirks, the mdd-H is much better for the specific build you mention (can even do an atm12+9 with lots of ammo and 3 hml+tag). In that case, using this stormcrow as 6ersl+2atm9 will be more varied in my garage, so thanks a lot for the suggestion!
