Eat your heart out, Remover! _ Essentially "Double Tap" but way less viable and way too hot with way too little ammo. But if you're around 200m and at resting heat? That's up to 184 damage without crits at the small, small cost of a bunch of internal structure. The best part is, if you're riding redline like a Honda Civic there are NO good options for weapons to use without suffering near catastrophic self-inflicted damage!
I can't remember exactly what a "bunch" was when I ran the build, but I feel like I died fairly quickly from structure damage... Tell you what, I'll run it tonight and see what's left of my internals after an alpha and override.
I literally just noticed that slot error while trying to get that shit to fit on my Boiler. I use AweMech for building and posting and on clan mechs it deletes lower arm actuators if you install a PPC or Autocannon regardless of if it's an omnimech or not, which led to my slot problem here. Gonna redo it on MechDB and edit the original post.
Top image is after my first alpha. Bottom is... well, after a second alpha, but I definitely wasn't at resting heat and I just kept firing UACs until my torso and arms disappeared.
Well, one out of three games was ok. Still learning the heat curve. You can full alpha and double tap with the versions with MPLs. I will have to try this out some more with the XL325 engine when I have time.
