Meme SR-4 "Amaris' Folly" (4xcGR, 4xcERLL, XL255)
Thread in 'SR-4' started by Remover of Obstacles, Oct 17, 2024.
  1. https://mwo.nav-alpha.com/mechlab?b=5d6fbdbd_SR-4
    Long range weapons platform. Typical firing will be firing one side and then the other. You can alpha for 74 damage. Decent sustain with 4x GR that can keep firing with those combined heat and ballistic heat quirks.
    With skills, you should be able to get through two cycles of firing (208 damage) before cutting back on ERLL usage.
    The speed skills will get this to 44 kph... I would prioritize cooling, armor and weapon skills, but that is me.
    Quirks
    • HEAT-5%
    • WEAPON VELOCITY+15%
    • BALLISTIC HEAT-7.5%
    • BASE ARMOR (CT)+20
    • BASE ARMOR (RT)+20
    • BASE ARMOR (LT)+20
    • BASE ARMOR (RA)+20
    • BASE ARMOR (LA)+20
    • BASE ARMOR (RL)+15
    • BASE ARMOR (LL)+15
    WG1 - Left side weapons
    WG2 - Right wide weapons
    WG3 - ERLL chainfire
    WG4 - 4x GR
    WG5 - Torso GRs
    WG6 - Arm GRs
    https://mwo.nav-alpha.com/mechlab?b=70a1cd01_SR-4
