STK-5M Graser-Light (3x LLas, 4x LRM5+A, AMS, STD300)
Thread in 'STK-5M' started by Heketon, Aug 16, 2013.
  1. Heketon
    Heketon New Member
    The original name for my 5M was Graser, a 5 x LLas gunboat. Now that we have heat buckets, this is Graser-Light. I've removed two of the large lasers and put in 4 x LRM-5. The LRM-5s are lightweight, reload fast, and are not in a silly heat bucket meaning that I can spam them until the magazines run dry.
    The main strategy for this little piggy is to LRM anything out of the range of my lasers (and to be honest, get cheap kill assists--teammates willing) and then light up anything inside 400 meters.
    The weapon groups are set up to chainfire missiles, chainfire lasers, alpha-strike missiles, and alpha-strike lasers.
    It runs fairly cool until I start button mashing in multi-opponent brawling conditions.
    [size=8pt]Edit: Spelling correction: s/Grazer/Graser/
  2. The Verge
    Fantastic work, This build I would run in a heartbeat. You can support your team while behind cover. You can snipe with the LL. you can brawl with the LL. 5-5 stars for this build.
  3. Cpt Chattahah
    I actually just started working on my Stalker again. I was running similar with the stock engine and 5xLRM5, 3xMLas & 2xLLas. The deadliest LRM boat I've played! Still... Expensive to grind through 3 variants. (the reason I stopped in the first place)
