STK-5M Heavy Missile Support MKII (2x LRM10, 2x LRM5, 2x LLas, 2x MLas, Tag, AMS, STD280)
Thread in 'STK-5M' started by Blagg Zear, Jul 10, 2013.
  1. Blagg Zear
    Everything you need for constant LRM.Pressure: 9tons of Ammo. 15 DHS. 2x LLas + 2x MLas. Tag.
    Blagg Zear
  2. IanSane
    IanSane Advanced Member
    339
    You always come up with awesome builds. I wanted a missile boat and looked around for one to base mine from. I am extremely new and only have 1 owned Mech at the moment which is a close in brawler so I wanted something polar opposite in playstyle and that would allow me to change up builds for different experiences... Laser build or Missile build would just have to change modules out. Starting with yours I came up with this. Thoughts?
    I am considering removing the Tag and installing another ton of Ammo. Or removing a laser but not sure yet. I want to do a few matches to figure out how much ammo I actually use in a match. I could also lose 2 of the 15s and put a 10 for more ammo...etc bottom line is its easily tweakable which is good because I seriously suck at the game and need all my options open. :) Reason for the XL300 is its already sitting in the garage.
    Very first match I got 700 damage on a city map. Keep in mind I am HORRIBLE at this game. Love to see what you GOOD players could do with it. I swapped a medium laser for 1 more ton of Ammo by the way.
  3. Blagg Zear
    thx, im glad you have success with lrm boat builds. XL Engines on Stalkers are very risky because of the big open Side Torsos, which get damaged first. If one of them get destroyed, youll die instantly. You must play very carefully and let your mates cover you. In Close Range you will have problems to survive long. Another thing - due to latest Heat Penalty Rule you will overheat very fast with more than two LRM15.Pods (if fired altogether). You need to fire in Pairs, then its ok. Have Fun & Good Luck!
    Blagg
  4. IanSane
    339
    Found out bout the heat issue, 4 quad volleys would get me near overheat so I once I put them in ripple the pain commenced... as I said with the engine, im still new and poor and had this lying around the shop from another Mech...Now if I can just get my teams to not lemming and light targets. I am not worried about ECM anymore its the fact I cant seem to get teammates to spot anything so I have ended up taking it closer into the fight
  5. Blagg Zear
    have you experienced with 4x LRM15, that you fire in several Volleys due to the limited Missile-Tube-Sizes (2x 10', 2x 6') ?
  6. IanSane
    339
    Actually no, only fired 1 volley per LRM15 for 4 total volleys per alpha.
