STK-5M Ice Cold Aggression (2x LLas, 2x LRM10, 3x SSRM2, 1x MLas, BAP, STD300)
Thread in 'STK-5M' started by Blagg Zear, Dec 9, 2013.
  1. Blagg Zear
    This is the build i used in the upcoming video in SubjectSeven's Irregular Adventures!. It's an experimental build for a more Allrounder Roleplay. You have some Indirect Firepower, two strong LLas for direct Firesupport and from up close some additional Firepower/Anti-Lights Defense with Triple Streaks and a single MLas. 18 Heatsinks provide decent cooling if firing in Weapongroups. Play it as a Secondline Fighter/Brawler and it can deal good scores. As said, experimental/fun and not very competitive due to allrounder playstyle.
    Best Attack Range: 180-270m for comboing everything at the enemy for Screenshakes and Armormelting. :cool:
    Blagg
  2. The Verge
    how do you find the 2 tons of streak ammo? is it enough, or does it need more?
  3. Blagg Zear
    it's ok, as i use them only to backup close range engagements or to defend against annoying Lights. For Streak.Brawling i suggest Penta.Streak builds for the STK-5M. I would rather like 1-2tons more LRMs for this build as i see the mainattack = LLas + LRMs combined at 180+m Range.
  4. TheWatchman
    TheWatchman Dispossessed
    Just a little tweak. Dropped an SSRM pack plus ammo for another MLas, AMS and ammo. Runs a little hotter than the OP, with a ton less armour, but more survivable ammo placement (IMHO).
  5. Blagg Zear
    but triple streaks are sooo much more shaky and cooler, dude! AMS is a good choice but i myself rarely run both BAP & AMS - use up too much critslots against high Cooling. This build runs hot as you can see in my video in the SubjectSeven's Irregular Adventures!
    About the Ammo placement. You really in your honest opinion find your placement safer?? :wtf:
    4 tons of LRMs take time to fire away. If any of those ammo.packs explodes, your sidetorso will get damage. IMHO Legs are rarely damaged, unless you run like a chicken on open fields and everybody is focusfiring at you.. :rolleyes:
