TBR-C "Dunali" (1x cLBX20, 4x cSRM6, 2x cERML, 1x JJ)
1 rating
Thread in 'Timber Wolf Omni Builds' started by e92, Jun 20, 2014.
  1. e92
    e92 Benefactor
    291
    Shotgun brawler build.
    - Reach out and touch mechs with the ERMLas
    - Strip armor with the SRM24
    - Crit-finisher with the LB20X. Stutter shot with this: shoot the SRMs into the torso twist, hit them with the LBX when they twist back.
    2 tons left over with 3 tons each of SRM and AC ammo. Your choice on what to do with those: JJs, DHSs or ammo.
    - While my C is basic, I am running two extra DHS.
    - When elited, its probably best to drop the two DHS and get an extra ton of each type of ammo, or one and a JJ.
    I am trying really hard to maximize sustained and max dps without using machine guns. They just are not very useful right now. The dynamics of the game have changed a bit and you really cannot hover around mechs for long enough for them to work. Alpha strikes are way too deadly. You either go in for the kill, or hang back where it is safe. If you go in to machine gun someone to death, you just take tons of damage.
    Edit: After 60 games, I prefer to have 5 tons of SRM ammo and 3 tons of LBX20
  2. e92
    e92 Benefactor
    291
    This is still the best pure brawler I've run on a timberwolf so far. The LB20X is so satisfying to shoot. No silly tin can like the UAC20. It comes out in one burst so it works with the jumpjets as well.
    Game log of this build:
    Code:
    Avg Dmg:654.25    K-D:133-35    KDR:3.800    W-L:35-25    Ratio:1.40
    Mode    Damage    Kills    Assists    Match Score    Death    W/L    Map        Mechs Killed
    c    700    2    4     91    #1        W    tourmaline    12-1
    c    504    0    8     70    #4    x    W    tourmaline    12-7
    c    509    2    8     79    #4    x    W    caustic        12-8
    c    620    2    6     91    #4    x    W    frozen        12-7
    c     83    1    0     11    #10    x    L    tourmaline    1-12 alpha went kappa
    2416
    c    471    1    2     77    #4    x    W    canyon        8-8
    c    121    0    0     14    #10    x    L    alpine        5-9 alpha bravo both went gamma
    c    346    2    7     59    #6        W    caustic        12-3
    c    400    2    4     52    #4    x    L    canyon        7-11
    c    975    3    6    129    #1        W    river        12-3
    2313
    4729    15-7
    c    557    4    4     83    #3        W    alpine        12-6
    c    485    0    9     70    #3    x    W    caustic        12-6
    c    692    2    3     82    #1    x    L    crimson        5-11                                            3109
    c    479    0    2     52    #2    x    L    forest        2-12
    c    499    2    6     61    #3        L    crimson        11-8
    2712
    c    163    0    0     17    #3    x    L    crimson        1-12
    c    282    0    3     34    #2    x    L    crimson        12-3
    c    993    1    10    131    #1        W    tourmaline    12-5 w/ epikt
    c    756    2    8    104    #1        W    hpg        12-4 ammo:lb14,srm0. lost the lbx early
    c    555    5    4     93    #1        W    caustic        12-6
    2749
    5461    16-5
    c    576    0    9     80    #2    x    W    hpg        12-8
    c    675    3    6     92    #1    x    L    hpg        9-12
    c    299    2    0     36    #1    x    L    therma        3-12 solo'd two lights 1v2
    c    950    5    4    142    #1    x    W    canyon        10-10 shot all srm ammo
    s    571    1    11     83    #3        W    caustic        12-3
    3071
    c    533    2    7     79    #2        W    crimson        12-6
    c    313    2    2     42    #6    x    L    hpg        7-4
    a    872    4    6    118    #1        W    frozen        12-5 srm0, lbx8
    c    858    6    3    104    #1        L    tourmaline    11-5 ooa completed srm0lbx0
    -removed 2dhs for 2 ammo-
    a    609    3    2     75    #1    x    L    tourmaline    6-12 shotgunned 3 mechs in the back. #2 was 327
    3185
    6256    28-6
    a    448    1    2     49    #2        L    forest snow    6-6 base rush. solo'd a DWF
    a    593    1    4     74    #2    x    L    caustic        5-12
    a    672    1    7     99    #2    x    W    alpine        12-8                                            3180
    c    642    1    4     71    #1    x    L    caustic        6-12
    c    275    0    4     44    #7    x    W    hpg        12-5 tunnel vision chased a thunderbolt into 6 mechs. took him down to 27% though
    2630
    c    772    3    5     95    #1        L    therma        9-3
    -mastered-
    a    452    2    7     68    #5    x    W    canyon        12-1 jagerXII alpha lance. bad overheat. only death
    s    641    2    9     90    #1        W    frozen        12-3
    c    1071    4    7    147    #1    x    W    hpg        12-2
    c    1160    2    1    123    #1    x    L    tourmaline    3-12
    4096
    6726    17-7    (23172 76 25 22 18)
    c    848    4    5    100    #1        L    crimson        11-5
    c    204    0    4     29    #6    x    L    caustic        5-12
    c    1105    6    3    143    #1        W    therma        12-6 2 lbx ammo, ooa srm
    c    570    1    0     62    #1    x    L    hpg        1-12 digustingly bad team
    c    677    2    9    108    #1    x    W    crimson        11-4
    3404
    c    222    1    1     27    #3    x    L    river night    3-12
    c    853    3    6    113    #1        W    forest        12-4
    c    1050    2    10    137    #1        W    forest snow    12-8
    c    1003    3    6    127    #1    x    L    alpine        10-8 LT killed me :)
    c    543    1    6     65    #3    x    L    forest        10-11
    3671
    7075    23-6
    c    741    3    9    111    #1    x    W    forest snow    12-5
    c    684    0    4     76    #1    x    L    forest        4-12
    c    1165    5    6    153    #1        W    frozen        12-7 eat shotgun!
    c    440    0    2     60    #7    x    W    river night    12-5 cored out the back not paying attention
    c    1077    4    5    146    #1        W    therma        10-3 srm0 lbx8
    4107
    c    1158    7    3    150    #1        W    frozen night    12-5 srm0 lbx6
    -switching to 5 ton srm, 3 ton lbx-
    c    992    3    6    134    #1        W    canyon        12-5 got wrecked at range at the beginning
    c    787    5    1    105    #1    x    W    frozen        12-6
    c    1169    6    3    149    #1        W    caustic        12-7 lbx6 srm 68
    c    795    3    7    118    #2        W    hpg        10-8 lost my left side with most of my ammo early
    4901
    9008    36-4
    dmg        k    d    w    l
    39255        133    35    35    25
    [size=8pt]Edit 2014-07-22: Updated game log
    [size=8pt]Edit 2014-07-29: Updated game log
  3. AH Khagas
    AH Khagas New Member
    I feel like this is the build I was trying to figure out when I posted the "Search and Destroy" build and I never quite nailed it down. Looks solid, I'm gonna definitely have to try it. Thumbs up.
  4. FlannelBeard
    FlannelBeard New Member
    Without a shadow of a doubt this is one of the best TBR-C builds out there. My first match I got 4 kills, 5 assists, and 825 damage. You play the TBR-C like a medium brawler mech, as with most TBR builds. Took on a full-health AC20 Atlas and took him out easily (they overheat easily, and mind you i had half armor left already). Whether or not I can withstand a Gauss Atlas is yet to be seen, as they dont overheat as often.
    The problem with this mech is heat. It can be a real problem when stripping armor face-to-face with a mech. Im almost wondering whether or not I should swap out 2 of the SRM 6's with SRM 4's, giving me extra slots for DHS.
    But honestly, stay with the pack and you'll absolutely love this build.
  5. Kage Supreme
    Kage Supreme New Member
    I was trying to do a Brawler build similar to this earlier. The combination LB and SRMS are absolutely brutal no matter what mixture they are in. I love my "Kick Puncher" TBR-S, but I can see this TBR-C build being an absolute monster. Will have to try it out later today.
  6. Cord78
    Cord78 New Member
    This thing is a beast... only problem is when you get stuck in a brawling scenario as it does run hot.
  7. e92
    e92 Benefactor
    291
    Agreed on the heat for the most part. You mostly have to be very conscious during brawling to only use the MLas for strategic shots that either finish an opponent or strip off one of their torsos before their next shot. While not shooting the MLas, your elited heat efficiency goes up to 62% with a sustained dps of 10.54.
  8. e92
    e92 Benefactor
    291
    Featured on Smurfy!
  9. Thiak
    Thiak Well-Known Member
    244
    i dont like clan srms without artemis, the spread is ridiculous (same for lrm)
  10. e92
    e92 Benefactor
    291
    I agree, its not ideal nor preferable, but the SRMs are not the primary focus of this build so I've been able to deal with the spread by using them at closer range if possible.
    I've been having ammo difficulties with the build in the original post as it is and have been running with 4 tons of each ammo instead of the two extra DHS. To upgrade the guidance to Artemis, I think you would have to drop one of the SRM launchers. That would let you run the build on any chassis and put the jump jet in the CT.
    That being said, I tried this build for a while and in the end preferred to have the punch of the posted build.
  11. S13gtastic
    S13gtastic New Member
    Only change I've made to this build is I dropped the Mediums for 4 small lasers and extra Lbx Ammo. Like it a lot surprised how often I consistently see 500-600 damage.
    I kinda feel like not enough people are taking advantage of the small lasers in builds, I just think of them as IS medium lasers with faster recycle times(which could just be something I made up...have to check now).
    The Lbx 20 and Srms make me go:
  12. e92
    e92 Benefactor
    291
  13. e92
    e92 Benefactor
    291
    Caught it being featured on Smurfy again ^_^
  14. Regina Redshift
    1,293
    Finally, a TBF build I can agree with.
  15. RockTripod
    RockTripod New Member
    I copied this build (hope you don't mind) and i've had some good successes with it. I did change it around a little. I dropped one SRM, and switch the ER lasers to Med. Pulses. There's a trade-off with damage in a single strike to be sure, but I don't overheat anywhere near as often. Ghost heat was a major concern for me with 4 SRM 6's.
  16. e92
    e92 Benefactor
    291
    A mech build is like a piece of sporting equipment. If you take Rafael Nadal's tennis racquet and you give it to Roger Federer, he'll still probably be pretty good with it, but he'll likely prefer the balance of the racquet and the string tension to be different. I'm glad to have inspired a build that fits like a glove for you :)
    Make sure you change out one of the torso's away from the S torso so you don't take the nasty quirks that go with their use. The most noticeable is that your SRM salvo's cooldown 5% faster.
    [quote author=RockTripod link=topic=7076.msg48664#msg48664 date=1405616644]
    Ghost heat was a major concern for me with 4 SRM 6's.[/quote]
    Just keep in mind that not all ghost heat is built the same. Excerpt from a different SRM24 build of mine:
    The heat penalty on firing a salvo of SRM24 is 17.20-16.00=1.20 heat. I think its a non-issue. It isn't exactly like firing, say 3 PPCs where the heat penalty on the 3rd is 57.15-45.00=12.15 heat.
  17. e92
    e92 Benefactor
    291
    Shout out to Ub3rMensch who destroyed my face in my own build while I was testing the Heretic loadout.
    I got snuck up on as we were flanked at the F5 ridge and got both of my side torsos shredded in 10 seconds flat from high health. I had to see what hit me so hard and caught a glimpse of the loadout on a friendly cam. I called him out for the build. Nice shooting friend :)
  18. e92
    e92 Benefactor
    291
    I had a long day at work so I took out my frustration on some scrap metal.
    Personal best for 5 game steak broken (5183/5=1036.6).
    Personal best for 10 game streak smashed (9008/10=900.8).
    Updated the game log.
    Just missed an ace.
  19. e92
    e92 Benefactor
    291
    For funzies. 14 games above 1000 in 98 games in the loadout :D
    Yes its a bit of a martyr. 6/14 of those games resulted in deaths.
  20. Madgoose
    Madgoose Well-Known Member
    5 stars from me.
    Did my 1st match with this monster and scored 5 kills, 6 assists and more than 700 dmg... :cool:
    (I admit that I've been lucky but still...)
