[size=14pt]Mr. 3000! This build is a jack of all trades. It basically rolls a 2x cERLL 4x cERML Stormcrow and a 4x cSRM6 Timberwolf into one. Group 1 - Both cERLL. Group 2 - All cERML. Group 3 - All cSRM6. Group 4 - Chainfire all cERML. Group 5 - Chainfire al cSRM6. Please leave feedback or personal build changes.
Who rated this build a 'One Star'? At first this may look way too hot, but consider this: At range, you can fire your lasers with 21 DHS with good efficiency- standard Laser-Vomit. But when the fight gets hairy, those lasers are hawt! Now you switch exclusively to the 4xSRM6, and brawl it out with 12 dps -they'll never (really) overheat you! And you still have 500 missiles. The only change I would make is to squeeze a jump-jet somewhere for the sake of maneuverability, but that's my personal preference. Clearly this is a flexible and powerful Timberwolf build, deserving of a good rating.
I like it! The large lasers give me range to hit and hide until I can get close and the rest is just loaded up brawly goodness. Can't wait to try this out! The only changes I would make is putting the large lasers in the torsos and the medium lasers all in the arms, but that's just my preference.
This build doesnt consider how large lasers are useless on a TBR because of the enormous burn duration. It is not a viable build because of the increased face time required. Your build has both Large & medium lasers, both of which are severely affected by the TBR negative quirks. Not a good build imo sorry. At least drop 2 of your medium lasers to reduce quirks. 2Large+2Medium should still give you a huge range DPS, while minimising the burn duration nerf as much as possible. If i was to improve the build, i would remove the medium lasers, use the 2 single energy TBR arms for the Large lasers and just play 4x ASRM6 + 2Large lasers, if i really want to try and make large lasers viable(they really really suck).
