First run. Hadn't basic'd that timber either as I play mediums for my clan. Very nice build. It's light on ammo but that's okay. You stay at range with the uacs and then switch to full on brawling. You'll notice people were happy to watch me pilot that beast. Tree in a Timber. Run You Fools! Another brutal match once I switched it to my Prime. http://i.imgur.com/PJPVm4X.jpg[/img] The repeated results suggests something awesome here. Thanks for the awesome build
Long time reader, first time poster! Consider this a longer range variant. By swapping the UAC5s for UAC2s I saved enough tonnage for Artemis, a TC1 and some extra ammo. The UAC2s don't, at least in my opinion, lose too much in the way of damage. You can really slam that UAC2 button and send out a hail of 1 damage projectiles. It does, however, run a little bit hot, both the ACs fired non-stop won't let your 'mech cool down on the hotter maps. You might want to consider removing some ammo and the TC for extra heat sinks or JJs if you're into that kind of thing.
Sadly, the coming fixed JJ changes are going to nerf this build a bit. Should work. Downgrading the SRM-6s to 4s makes up for one lost ton, losing some ammo 'buys' the other. On the otherhand, silver lining will be slightly better heat and some jump/climb ability, and you'll still have 12.5 volleys with the launchers. [edit]As smurfy updated with fixed JJs, fixed build to comply[/edit]
