While I was browsing the TDR-9SE builds looking for inspiration when I found Ch_0me's Hole Puncher build and decided to convert it for use in the 10SE. It has 800 Rounds of MRMs but its enough for casual play but if you want to add another ton of ammo drop the engine down to an LE295 and add another DHS. _ I was also able to make a version of Excalibaard's modification for 5xMPLs, the engine is a LE280 like that version but thanks to the MASC you can push for a bit of extra speed when needed and an extra half ton of MRM ammo. _ EDIT: Sorry I noticed, I accidentally used the (S)pecial variant of the 10SE, you can use the build on the standard 10SE as well.
