TDR-9S "Hot Shot" (3x ERLLas, 1x LRM5, 3x MLas, 2x AMS, XL315)
Thread in 'TDR-9S' started by the boneshaman, May 15, 2014.
  1. the boneshaman
    the boneshaman Active Member
    I have had the most luck with this Load out. On hot maps the ERLL are chain fired the arm weapons are linked helps with lights and critting. 2 ML are linked in the LT. the LRMs help soften up or finish off targets. One rework of this load out is to drop the XL LRMs and ammo and 1 DHS for a 280 standard your slower and have a higher survivability. how ever with the luck I have had with this mech when I have an XL I always die by LT/RT shot out. with the standard engine I never get lucky enough to get a LT/RT shot out and keep going always I get killed by CT shot out. so I said F.. it ill just stick to speed.
  2. enileph
    PROBLEM ONE: WHY ON EARTH DO YOU PUT MOST OF YOUR SIDE TORSO ARMOR TO THE BACK? I KNOW YOUR TEAM CAN BE IDIOTS AND FRANKLY I NEVER TRUST THEM BUT IT IS STILL BETTER TO HAVE MOST OF YOUR ARMOR UP FRONT.
    The single LRM5 may not worth it. I know, enable enemy warning for crowd control and such, but still. Any AMS and it is gone.
    The additional LLas on your LT may be weird, I suggest moving it to the arm. It is sometimes unpredictable where the LLas will show up, sometimes when you build it the LLas shows up in the low mount making it a bitch to use.
    I would use LLas in the arm instead, but I did not change it here, so you can still snpe with triple ERLLas.
    The ERLLas for long range snipery thing, and at closer range you can use your arm to the advantage. Replace LRM5 with SRM4, which is more useful close range.
    http://mwo.smurfy-net.de/mechlab#i=155&l=7cb8d9f72903ddeace5aba458ace241d984df724
    This one use LPLas for close encounter instead.
  3. the boneshaman
    oops o_O on the armor lol did not mean to do that. I think i fixed it. I tryed using the SRMs but i can't hit the ground with them. Tryed using LLasers. Hate not having the rang when I need it. At one point I had one ERLL on the arm didnt like having all my LL on one side.... but that was when i was running a standard eng.
