I like the Concept of the "Cyclops" Build with Double LLas for Long Range Attacks, but i think two SRM6s make much more Punch at Close Range than two SRM4s+ (third)MLas. On the other hand the position of the Sidetorso.Hardpoints seem to be higher and so more viable for Sniping. AMS provides some Protection against Long Range Spammers. Alternate "Cool" Edition by dropping AMS: Alternate "XL" Edition: testrun: Blagg
Love this build, I'm cheap though and using a stock engine, which allows for one more ML and one more ton of srm ammo.
Yeah why not. But i think you need more Cooling with another MLas, especially on hotter maps. Maybe drop one JJ for another heatsink.
Sort of a cross between the 260 build and the OP build. More srm ammo instead of 3rd medium laser. Moved large lasers into torso. I just think they're better there. I like having the mediums in my arm so I can more easily shoot lights harassing me with them.
Also made my variant from it: I preferred to put in another DHS together with the 3rd ML, because I mostly use jumpjets for turning in a brawl or faster hill climbing (sometimes small obstacles) and find 1 JJ is enough for that. Put the remaining ton from freeing up slots into the shield arm and my legs. Still runs a bit hot so i advise against using the LLs in a brawl. It might be a good idea to swap out 2 MLs and the LLs in the arm for better aim in close range engagements (not everything in left torso) but my OCD wouldn't let me. Also shifted the armor around a bit.
First match with Blagg's Std.275 I got 3 kills, 3 assists and 500 damage. That is a HUGE improvement from what I was accomplishing before with my 9SE. Great build!
I can't seem to do squat with the standard build. The (relatively) low armor on the legs is the death of me.
