UM-R63 "NEWBIE" (1x UAC5, 2x SPL, 2x MG, XL125) +ALT
Thread in 'UM-R63' started by Xenithos, Apr 18, 2015.
  1. Xenithos
    Xenithos New Member
    I know, obnoxious title, I'll be posting some matches in a couple of days to prove it, but I think the smurfy stats say it all:
    CLICK the NAMES of the two builds to see them.
    Alpha:
    Alpha's job is much like that of a balanced blackjack. Add fire support while staying around big guys. Then when armor falls off, rush in and take the kill.
    Bravo has a couple of changes for you guys out there with the xl 180 that you need to put to use.
    Additional changes to bravo include taking off the jump jets for another small laser or another half ton of UAC ammo.
    Bravo:
    Just remember that Bravo's job isn't neccessarily to stay with the heavies anymore. You can keep up with the mediums, but still try to stay out of harm's way. And you are slightly weaker with less ammo all around, as tradeoff for speed.
    Thanks for the Edit guys, I reviewed CoC, thanks.
  2. Spheroid
    Spheroid Well-Known Member
    202
    append the hyperlink to be https: instead of http:
  3. Michael
    I've fixed the code. Please fix the title or this one will be deleted as well.
  4. The Verge
  5. enileph
    I suggest something like this:
    It may be nice to replace SPL with ML, depending on your playstyle. I think MG+SPL is fun though.
    Speed you can get by having half ton MG ammo. That said, you may run out if you stay close for too long, so I suggest ML instead of SPL for this build.
