VTR-9S "Terminator" (1x AC20, 2x ML, 2x SRM4, 1x SRM2, 1x JJ, STD320)
Thread in 'VTR-9S' started by Blagg Zear, Jul 23, 2013.
  1. Blagg Zear
    Remastered Edition of my Terminator Build with STANDARD ENGINE. I dont like the Combination of XL Engine and Short Range Boomstick. The Reason why I dont use double SRM6 is because of the Spread (no Artemis) & I want one Alpha.Volley due to limited Tube Size, and I rather have more Ammo for the BFG.
    Alternate "XL375" Version:
    testruns:
    Also try out the MKII: https://www.mechspecs.com/threads/v...x-lpl-1x-ml-2x-srm4-1x-srm2-1x-jj-xl350.2616/
    Blagg
  2. The Verge
    I think this build is a bit better than your other victors. Plenty of ammo, AMS, and JJ. All with a STD engine. 4-5
  3. Cpt Chattahah
    I've been having problems with the SRMs coming out in volleys in the 9S even though I should have adequate tubes for my loadout. Anyone else having the same?
    Good loadout, Blagg. Just ran it for a bit. 400-600 almost every round. Nice.
  4. FuzzyBunny
    FuzzyBunny MechSpecs Addict
    Excellent build. I used it for the base on what I'm running. 4-5.
  5. don Zappo
    don Zappo Advanced Member
    428
    46
    Excellent builds! I prefer the build with the XL365 in it for the super happy punchy speed. If I want a slow walking brick, I'll just run my atlas. :p
    I definitely think these builds need more press. So, have a rating and a bump!
    Here's the slightly modified variant that I run:
  6. knightsljx
    knightsljx Well-Known Member
    129
    nice build but just a suggestion. if you have spare slots, don't use the engine slots for DHS, place them in the side torso. It reduces the chance of a critical hit on a weapon or ammo.
  7. MinusMaximus
    MinusMaximus New Member
    just my 2 cents based on the stuff i have lying around
  8. Logi
    Logi New Member
    the alternate jumper is a nice build i will try. but i am shootnig the 10 srm not in 1 volley, but in 2. 8 srm followed by 2. think i have to remove the SRM2
  9. Motörhead
    5* build !
    Would run a slight mod (don't like low leg armor, and case is perfect for this build). After clan invasion it's safe to drop to a 315 and gain a DHS and more crit padding (needed for a brawler especially) dropping 1kmph
    And running and XL is a real nerf to this build, when 1 side is gone you are still fearsome, so I like the original STD design.
    If I were to run an XL, I'd want to be REALLY fast, and armored :
