This is the most fun in a Warhawk that I have ever had. I have the weps set to chain fire in each arm but just tap the wep groups to get them to fire faster if I need them to. I like the use of the MK V comp over AMS since I have Target Derp module.
Can't go too fast on shooting cause of ghost heat even if chained. Now, this is less firepower and more heat, but no ghost heat at least.
I very very seldom over heat. Even on caustic. Where as with my Warhawk B build that uses dual PPC it gets hot real fast. All you have to do is wait 1/2 a second between shots and you are smooth sailing my friend.
The build is just fine and have seen it work well driven by other pilots or myself. If ghost heat is a problem with a 49% heat eff, then it's not the build...
