WHM-6D "Ban Hammer" (9x ERLL, XL255)
Thread in 'WHM-6D' started by Solahma, Feb 2, 2016.
  1. Solahma
    well... considering it's the only IS mech that can fit 9x ERLL so far, it had to be done. (edit: yes, the Top Dog can fit it, but with half as much armor and no heat gen quirk :cry:)
    I was requested to drop it on stream. As you might assume, it's pretty terrible. BUT it can certainly be fun on the right map and given the right situation.
    At least it's faster than a DWF!!!
    I setup a macro to fire 3x3x3 as quickly as possible, but still avoiding ghost heat. I'm thinking of running this again for fun and perhaps making a video. I'll try to get the macro times posted as well incase anyone is curious.
    ~1 hour of original gameplay and fking around with the macro until it was working properly
    video>>>9x ERLL WHM-6D CSJ META STREAM <<<video
    didn't get the macro figured out until ~10 minutes in.
  2. Aylek
    Top Dog can do this as well if I am not mistaken, but the cooling efficiency will probably be even worse there.
  3. Solahma
    True, it could technically fit it. It would have half as much armor as the WHM though. WHM gets ~9 tons of armor. Top Dog could only have ~4 tons. Pretty huge difference when the WHM is already only running at 66% armor.
    Also, like you said, the Top Dog without a heat generation quirk would run hotter.
    Both its heat and its even greater lack of armor makes it non-viable. Whereas the WHM is actually a gimmick that could do something lul
    still dumb :hilarious:
    Gasboy and Aylek like this.
