WVR-6R "Duelist" (1x Gauss, 2x SRM-2, 1x Flamer, 6x JJ, Xl 300)
Thread in 'WVR-6R' started by vipershark, May 13, 2014.
  1. vipershark
    vipershark Junior Member
    I've had luck going 1v1 in duels with this load out, but I can peg lights half the time with the Gauss at a bit of range, so take that into consideration, you need to be good with Gauss. Flamer instead of Medium because I use no heat and could use a short range punch, and I wanted to be a dragon. Sparingly use ammo, It has just enough, but not if you waste it.
