ZEU-6T "Titan" (3x SRM6+A, 4x MPLas, STD320)
4/5,
1 rating
Thread in 'ZEU-6T' started by Flokoloko, Mar 20, 2015.
  1. Flokoloko
    This build was what first came to my mind, when i saw the Hardpoints and now, here it is.
    Edit: This Posting is a little bit short for my first own build, so some thoughts:
    It is cheap (STD Stock Enigne)
    It is very durable (thanks to STD Engine and Armor Quirks)
    It has much brawling power
    Drawbacks:
    Lack of long range firepower
    A little hot, but I managed to get 1k Damage without all basic skills
    If you lose your right arm, you lose most of your firepower.
    In my opinion, the 6T is the best ZEUS variant so far.
  2. Jack Red
    Jack Red Active Member
    53
    Great Build.
    First build I tried as well.
    Only played 2 rounds with it, one was 735 dmg, the other was 695 dmg.
  3. Irrelevant
    Irrelevant New Member
    I like the build just one question on heat control. When you fire the SRM6s is it group or chain fire?
  4. Flokoloko
    I normaly fire them in group of all 3, but when the heat is allready critical I fire single srm6 shots. It`s also a mather of the target, if i can take an enemy down for the cost of overheating, i blast him away^^.
  5. Irrelevant
    strong build good thought on limitations and uses
  6. Apnu
    Apnu Active Member
    99
    I tried this build for a while. I don't know if its because there's a high number of ZEUs running around and there's a good number of players who aren't running them but wanting to beat them or what, but that right arm is a fire magnet. I was facing a couple of enemy mechs and they went right after the right arm despite the AC40 KGC right next to me blowing their heads off. They'd rather take that arm of the ZEU-6T than deal with a KGC... crazy. I'm skipping this build until the ZEU-6T looses that new mech smell.
  7. Decadre
    Decadre New Member
    This is my variation. 200 less ammo, but for the most part I typically never run out.
